Prep Time
Cook Time
Total Time
10 minutes
30 minutes
40 minutes
Chicken is affordable, delicious, and easy to cook, making it perfect for weeknight dinners. Baked chicken thighs are especially remarkable - crispy on the outside, yet still tender and juicy on the inside. This isn’t just hype. Thigh meat naturally has higher fat content than the breast, and that extra moisture prevents the meat from drying out during baking. Most importantly, they only take 40 minutes to cook, and are absolutely delicious.
Ingredients:
  • 6 chicken thighs, bone-in, skin-on
  • 2 tablespoons olive oil
  • 1 teaspoon kosher salt
  • 1/4 teaspoon freshly ground black pepper
  • 1 teaspoon garlic powder
  • 1 teaspoon onion powder
  • 1 teaspoon paprika
  • 1/2 teaspoon ground cumin
  • 1/4 teaspoon dried thyme leaves
Equipment:
How to Get the Crispiest Skin on Baked Chicken Thighs?
Getting crispy chicken skin is easier than you might think, and it mainly depends on dry skin, melted fat, and high heat. Here are the tips:
  1. Thoroughly dry the chicken. Pat the thighs dry all sides with paper towels, then let it air dry at room temperature for 30 minutes.
  2. Place the chicken thighs skin-side up. The heat will quickly render the fat and crisp up the skin.
  3. Leave some space between the thighs. Crowding them will affect browning and result in soggy skin.
  4. Use a hot oven. Preheating your oven to 400°F / 204°C is best for both crispy skin and juicy meat.
  5. Finish under the broiler. Once the thighs are fully cooked, move them to the top rack of the oven and broil for 2 to 3 minutes. Watch it the whole time.
RELATED: Crispy Air Fryer Chicken Thighs
How to Keep the Meat Moist and Juicy?
While the skin gets all the attention, the meat underneath matters more. So, here’s how you can keep your baked chicken thighs moist and juicy:
  • Bring the chicken to room temperature. Take the thighs out of the fridge 30 minutes before cooking.
  • Use a wireless meat thermometer. The USDA says 165°F is safe, but chicken thighs actually get more tender at 180°F.
  • Let the chicken rest for 5 to 10 minutes after baking so juices redistribute.
To make chicken thighs fall-off-the-bone tender, check out this sous vide chicken thigh recipe.
Baked Chicken Thighs Times and Temp Guide
Here’s the thing about baking chicken thighs. You can follow every recipe in the world, but your oven runs a little different than mine. That’s way this chart is a starting point, not the final work. Use it as a guide, but trust your thermometer.
Oven Temp
Bone-In, Skin-On
Boneless, Skinless
Internal Temp
What You Get
350°F
45-55 minutes
30-35 minutes
180°F
Extremely tender meat, but it’s almost like braising
400°F
35-45 minutes
20-25 minutes
180°F
Nicely browned skin and juicy meat
425°F
25-35 minutes
18-22 minutes
180°F
Really crispy skin, almost charred in spots
How to Bake Chicken Thighs in the Oven?
Step 1: Preheat. Set the oven to 400°F. Place a wire rack on a rimmed baking sheet. No rack? No problem. Just use a baking dish. It’ll still work.
Step 2: Dry and season. Pat thighs completely dry with paper towels. Get in all the little folds and creases. Then, rub with olive oil and season generously with salt, pepper, and any other spices.
Chicken Thighs Seasoned in a Bowl
Step 3: Insert the thermometer. Push the wireless probe into the thickest part of one thigh. Make sure the tip is in meat, not touching bone. Set your target temperature to 180°F in the app.
Step 4: Arrange and bake. Place thighs skin-side up on the rack with space between each. Bake until the thermometer beeps, usually 35 to 45 minutes for bone-in.
Baking Chicken Thighs in the Oven
Step 5: Finish under broiler. Move the pan to the top rack and turn the broiler on high. Watch closely so the skin doesn’t burn. 2 or 3 minutes is enough.
Step 6: Rest and serve. Transfer the thighs to a plate and let them sit for 5 to 10 minutes. After that, serve them up. The skin should be crackly, the meat juicy.
RELATED: How to Bake Crispy Chicken Wings in the Oven?
Baked Chicken Thighs Out of the Oven
How to Store and Reheat Leftovers?
Put leftover baked chicken thighs in an airtight container and refrigerate for up to 4 days or freeze for up to 3 months. If freezing, wrap them tightly or use a freezer-safe container to prevent freezer burn.
To reheat, the oven works best. Preheat to 350°F, place the chicken on a rack over a baking sheet, and heat for 15 to 20 minutes. If you're worried about drying out, cover with foil for the first 10 minutes, then uncover to re-crisp the skin. The microwave is faster but will make the skin rubbery.
Do I need to flip chicken thighs when baking?
No. Leave them skin-side up the whole time. Flipping can tear the skin or make it stick.
What is the best temperature to bake chicken thighs?
400°F is the best balance to crisp the skin and make the meat juicy in under an hour.
Should I cover chicken thighs with foil when baking?
No. Foil traps steam and makes the skin soft. Leave them uncovered.
How do I know when chicken thighs are done without a thermometer?
The juices should run clear when pierced, and the meat should be opaque. But a wireless thermometer removes all guesswork.
Can I bake frozen chicken thighs?
Yes, but it’s not ideal. Add about 50% more time to the baking estimate. Bake at 375°F and check temperature to make sure it’s fully cooked. For better results, thaw in the refrigerator overnight first.
