Jump to a recipe
A weeknight dinner doesn’t mean to be high-calorie takeout, and a healthy dinner doesn’t mean to be bland salads. With my easy, healthy dinner ideas, you can enjoy delicious, nutritious meals that also help with your weight management. Don’t worry, they’ll all fill you up, so you don’t end up rummaging through the pantry an hour later. Let’s check them out.
Sous Vide Chicken Breast
Nutrition (per 100g cooked) Calories: 120-135
Protein: 22-23g
Total Fat: 1-2g
Saturated Fat: <0.5g
Carbs: 0-1g
Cook Time: 1-2 hours (hands-off)
Equipment: Sous vide cooker
This method solves the biggest problem with chicken breast: dryness. The sous vide bath holds a precise temperature, so the meat stays juicy and tender without needing extra oil or butter for moisture.
Slice it over a bed of greens with cherry tomatoes and cucumber for a quick salad. Or shred it and mix with Greek yogurt, diced apples, and a handful of walnuts for a chicken salad that works as a wrap filling or a lettuce cup.
Pan-Seared Ahi Tuna Steak
Nutrition (per 4 oz serving) Calories: 130-206
Protein: 25-41g
Total Fat: 1-9g
Carbs: 1-5g
Cook Time: 4-6 minutes
Equipment: Cast-iron skillet
Ahi tuna is one of the leanest fish options out there. The sear takes barely two minutes per side, so you get a warm, crusty exterior and a raw, silky center. No heavy sauces needed - just salt, pepper, and a hot pan.
Slice the seared tuna thinly and serve over a bowl of brown rice with avocado, edamame, shredded carrots, and a drizzle of low-sodium soy sauce. Or tuck slices into a whole-wheat tortilla with shredded cabbage, pickled ginger, and a squeeze of lime.
Zesty Black Bean Burgers
Nutrition (per patty) Calories: 197-222
Protein: 9-11g
Total Fat: 1-2g
Fiber: 7-10g
Carbs: 28-41g
Sodium: 290-673mg
Cook Time: 15-20 minutes
Equipment: Non-stick skillet
Black bean burgers bring fiber and plant protein together in a way most veggie patties don’t. Each burger (around 4 inches wide) typically provides 7-10g of fiber and roughly 11g of protein. Fiber helps with satiety, so you stay fuller longer on fewer calories.
Serve on a whole wheat bun with lettuce, tomato, red onion, and a smear of mashed avocado instead of mayo. Or skip the bun entirely and wrap the patty in butter lettuce with salsa and pickled jalapeños.
Sous Vide Filet Mignon
Nutrition (per 3 oz lean serving) Calories: ~450
Protein: 40g
Total Fat: ~35g
Saturated Fat: 15g
Carbs: 1g
Sodium: ~400mg
Cook Time: 1-4 hours (hands-off)
Filet mignon is one of the leanest cuts of beef. The sous vide lets you cook it to the exact doneness you want, edge to edge, without overcooking. A 3-ounce serving of trimmed lean beef tenderloin contains around 40g of protein and roughly 450 calories, with saturated fat kept in check when you trim visible fat.
Slice the cooked filet over a large spinach salad with strawberries, walnuts, and a light balsamic vinaigrette. Or serve it alongside roasted asparagus and a small portion of sous vide potatoes.
Air Fryer Chicken Breast
Nutrition (per medium breast) Calories: 265
Protein: 38-42g
Total Fat: 7g
Carbs: 1g
Fiber: <1g
Cook Time: 18-22 minutes
Equipment: Air Fryer
You use less oil and still get that crispy, browned exterior. The air fryer also preheats fast, so dinner comes together in under 20 minutes.
Cut the cooked chicken into strips and toss with romaine, Parmesan cheese, and a light Caesar dressing. For a Caribbean twist, serve the breast with black beans, corn, bell peppers, and a squeeze of lime over cilantro rice.
Beef Chuck Pot Roast
Nutrition (per 100g lean trimmed serving) Calories: 139
Protein: 22g
Total Fat: 5g
Saturated Fat: ~1.9g
Carbs: 0g
Sodium: 74mg
Cook Time: 3-4 hours
Equipment: Dutch oven
When you trim the fat before cooking, the lean meat underneath delivers solid protein without the calorie load. The slow braise also tenderizes tough cuts without adding oil or butter.
Serve a 4-ounce portion with roasted carrots and a small baked sweet potato. Or shred the leftover meat into a broth-based vegetable soup for two more days of easy dinners.
Oven-Baked Chicken Thighs
Nutrition (per 100g skinless roasted) Calories: 200-209
Protein: 20-26g
Total Fat: 11-12g
Saturated Fat: ~3g
Carbs: 0g
Iron: 0.9mg
Cook Time: 35-45 minutes
Equipment: Oven
People think chicken thighs are off-limits for weight loss because they’re darker meat. But a 100g serving of skinless roasted chicken thigh has only 209 calories and provides 26g of protein, with 11g of fat. The extra fat actually helps the thighs stay moist during baking, so you don’t need to add heavy marinades or oil.
Shred the cooked thighs into bell pepper strips and sauté quickly with fajita seasoning. Serve in lettuce cups with salsa and a dollop of Greek yogurt. Or slice the thigh meat and layer onto flatbread with roasted zucchini and a sprinkle of feta.
Sous Vide Shrimp
Nutrition (per 4 oz serving) Calories: 207
Protein: 25g
Total Fat: 4g
Carbs: 19g
Fiber: 1g
Sodium: 340-1692mg
Cook Time: 20-30 minutes
Shrimp cooks fast, but it’s easy to overcook. The sous vide bath holds a steady 140°F, so the shrimp turns out tender and plump every time. You can season lightly or go bold - the method works with anything from garlic butter to Creole spice.
Toss the cooked shrimp with zucchini noodles, cherry tomatoes, and a quick lemon-olive oil dressing. Or chill the shrimp and serve over mixed greens with mango, red onion, and a squeeze of lime.
Sous Vide Salmon
Nutrition (per 4 oz serving) Calories: 280-350
Protein: 30-35g
Total Fat: 15-20g
Omega-3: 1-2g
Carbs: 0g
Sodium: 60-100mg
Cook Time: 45-60 minutes
Salmon is packed with omega-3 fatty acids, which help reduce inflammation and support heart health. Eating two servings of salmon per week can help meet your omega-3 needs, and the sous vide method preserves those delicate fats better than high-heat roasting or frying.
Flake the cooked salmon into a bowl of quinoa, cucumbers, tomatoes, olives, and a sprinkle of dill. For a warm meal, serve it over roasted Brussels sprouts tossed with a little balsamic glaze.
Pan-Seared Top Sirloin
Nutrition (per 4 oz lean serving) Calories: 180-210
Protein: 26-30g
Total Fat: 8-12g
Saturated Fat: 3-4g
Carbs: 0-1g
Sodium: 45-80mg
Cook Time: 8-12 minutes
Top sirloin is one of the leanest beef cuts you can buy. The Mayo Clinic and American Heart Association both identify top sirloin as a “lean” or “extra lean” choice, meaning it has less than 10g of total fat per 100g serving.
Slice the steak thinly and serve over a spinach and arugula salad with roasted beets, goat cheese, and a red wine vinaigrette. Or eat it simply with steamed green beans and a small baked potato.
Stovetop New York Strip
Nutrition (per 6 oz serving) Calories: 263
Protein: 39g
Total Fat: 11g
Saturated Fat: ~4g
Carbs: 0g
Dietary Fiber: 0g
The New York strip comes from the short loin and has a good balance of tenderness and beefy flavor without the heavy marbling of a ribeye. It’s lean enough for a weight-loss diet but still satisfying.
Slice the rested steak and serve over a warm lentil and roasted red pepper salad. Or pair it with a side of steamed broccoli and a half-cup of whole-grain couscous. Keep the pan sauce simple, maybe a splash of beef broth and a little mustard, instead of heavy cream.
Spiced Carrot & Lentil Soup
Nutrition (per 1.5 cups) Calories: 305
Protein: 12g
Total Fat: 12g
Saturated Fat: 4g
Carbs: 34g
Fiber: 9g
Cook Time: 45 minutes
Equipment: Large soup pot
This particular soup combines red lentils with carrots. A serving, roughly one and a half cups, has about 305 calories, 12g of protein, and 9g of fiber - very filling numbers for a broth-based meal. It’s also cheap to make and freezes beautifully.
Serve the soup as the main event with a side of whole-grain toast for dipping. Or pair a smaller portion with a mixed green salad topped with chickpeas and a squeeze of lemon.
Final Words
These recipes are designed to be flexible. The nutrition numbers listed are estimates for the base protein or main dish. For weight loss, pair each with a generous serving of non-starchy vegetables like broccoli, spinach, bell peppers, zucchini and keep added oils and sauces minimal. A little flavor goes a long way when the meat is cooked well.
